Aller au contenu principal
Sony Cyber-Shot DSC-W170 Top Panel Replacement
Ce dont vous avez besoin
  1. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: étape 1, image 1 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: étape 1, image 2 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: étape 1, image 3 de 3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 2, image 1 de 1
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 3, image 1 de 1
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: étape 4, image 1 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: étape 4, image 2 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: étape 4, image 3 de 3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 5, image 1 de 1
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: étape 6, image 1 de 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: étape 6, image 2 de 2
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 7, image 1 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 7, image 2 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 7, image 3 de 3
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 8, image 1 de 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 8, image 2 de 2
    • Gently push the connector through the hole to separate the LCD from the metal casing.
  9. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: étape 9, image 1 de 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
  10. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 10, image 1 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 10, image 2 de 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 10, image 3 de 3
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
  11. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 11, image 1 de 1
    • Lift the two flat ribbon cables with tweezers.
  12. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 12, image 1 de 1
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
  13. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 13, image 1 de 1
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
  14. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 14, image 1 de 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 14, image 2 de 2
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
  15. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 15, image 1 de 1
    • Push out the lens assembly very gently.
  16. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 16, image 1 de 1
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
  17. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 17, image 1 de 1
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
  18. Sony Cyber-Shot DSC-W170 Top Panel Replacement: étape 18, image 1 de 1
    • Pull the top panel off gently.
Katharina Anglett
Membre depuis le 09/13/23
529 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 17
Total : 131
