Aller au contenu principal
Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement
Ce dont vous avez besoin
  1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Battery: étape 1, image 1 de 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 2, image 1 de 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 3, image 1 de 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: étape 4, image 1 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: étape 4, image 2 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: étape 4, image 3 de 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 5, image 1 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 5, image 2 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 5, image 3 de 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 6, image 1 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 6, image 2 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 6, image 3 de 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: étape 7, image 1 de 2 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: étape 7, image 2 de 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 8, image 1 de 2 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: étape 8, image 2 de 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: étape 9, image 1 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: étape 9, image 2 de 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: étape 9, image 3 de 3
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Lift the capacitor from the assembly.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the flash board.
Tong Tang
Membre depuis le 09/15/16
590 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 17-1, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 24
Total : 1,028
