Introduction
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
Ce dont vous avez besoin
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Pry the device open with the plastic opening tool.
There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
4 autres ont terminé cette réparation.
5 commentaires
hii
plaz help me
pless need a sony dsc-'''''wx''''' 830 display LED
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Sony dsc s2000 model camera need
Display & lens unit
