Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Replacing the motherboard may seem like a daunting task but can be done using prying tools.
Pièces
Aucune pièce spécifiée.
  1. Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
    • Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
    • For further reference, consult the service manual. Link to service manual.
  2. Remove these two black M1.4 X 3.5 Phillips head screws.
    • Remove these two black M1.4 X 3.5 Phillips head screws.
    • The third, unmarked screw does not need to be removed at this time.
  3. Orient the device so the LCD is facing you, and the hdmi cover is facing up ("left view).
    • Orient the device so the LCD is facing you, and the hdmi cover is facing up ("left view).
    • Remove these three black M1.4 X 3.5 Phillips head screws.
    • You must lift the hdmi cover to expose one of the screws.
  4. Orient the device with the Wifi/GPS logo facing up ("right view").
    • Orient the device with the Wifi/GPS logo facing up ("right view").
  5. Use a prying motion and a plastic opening tool to pry the side panel up. Areas under the squares are approximate locations of retaining claws, shown at right. Be careful not to break any of the retaining clips as you pry up this panel.
    • Use a prying motion and a plastic opening tool to pry the side panel up.
    • Areas under the squares are approximate locations of retaining claws, shown at right.
    • Be careful not to break any of the retaining clips as you pry up this panel.
    • An image from the Service Manual has been added, which shows this side cover should be slid down before being removed, not just pried up as shown in the first picture in this step.
  6. After removing the panel, remove the two black M1.4 X 3.5 Phillips head screws.
    • After removing the panel, remove the two black M1.4 X 3.5 Phillips head screws.
  7. Orient the device so that the LCD is facing you ("back view").
    • Orient the device so that the LCD is facing you ("back view").
  8. Essential Electronics Toolkit
    Petit kit. Grandes possibilités.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  9. Use the plastic opening tool with a prying motion, going between the case and the LCD, from the middle of the LCD to the right of the device, undoing the claws retaining the back.
    • Use the plastic opening tool with a prying motion, going between the case and the LCD, from the middle of the LCD to the right of the device, undoing the claws retaining the back.
    • When replacing the back cover of the device, ensure the flash module is UP.
    • The back cover should come off easily but you might hear light snapping or popping.
    • The rotary wheel and button are not secured. They will come loose when the back cover is removed. Set them aside for reassembly
  10. Unhook the small printed circuit board by gently pressing the board towards the top of the device and lifting up.
    • Unhook the small printed circuit board by gently pressing the board towards the top of the device and lifting up.
    • Note a ribbon cable should be attached at the top. This does not need to be disconnected yet.
  11. Using a plastic opening tool remove the black LCD retainer clip to the right of LCD.
    • Using a plastic opening tool remove the black LCD retainer clip to the right of LCD.
    • Note the orientation of the black LCD retaining clip and how it comes out of the camera.
    • If in doubt, consult the service manual. (Pages 25-27) Click to continue to the service manual. This has a reference number of 3 in the linked diagram.
  12. Use the plastic opening tool to gently lift the LCD from the device
    • Use the plastic opening tool to gently lift the LCD from the device
    • The LCD should be attached to a ribbon cable
  13. Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
    • Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
    • Be careful to not damage the cable.
  14. Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of device.
    • Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of device.
    • If you have already removed the lens block, or aluminum back plate, you can skim over the next couple of steps until you are at a familiar place.
  15. Reorient the camera so you are looking at the "top view".
    • Reorient the camera so you are looking at the "top view".
    • Remove the black M1.4 X 3.5 Phillips head screw just below the ON/OFF button circled in red.
  16. Orient the device so you are looking at the "bottom view".
    • Orient the device so you are looking at the "bottom view".
    • Remove the black M1.4 X 3.5 Phillips head screw located next to the tripod attachment.
  17. Lift the aluminium back plate.
    • Lift the aluminium back plate.
  18. The connections (red squares) have small black retaining clips. Using a plastic opening tool, lift upward towards the cable to unlock.
    • The connections (red squares) have small black retaining clips. Using a plastic opening tool, lift upward towards the cable to unlock.
    • After detaching retaining clips, gently lift to disconnect the ribbon cables.
    • Don't rip the cables.
  19. Remove the orange M1.4 X 3.5 Phillips head screw located near the bottom of the camera.
    • Remove the orange M1.4 X 3.5 Phillips head screw located near the bottom of the camera.
    • This is the only screw that is orange.
  20. Lift up the motherboard.
    • Lift up the motherboard.
    • In this picture the lens block is removed, but it is not a necessity.
    • Disconnect the ribbon cable on the bottom by gently pulling.
Bryson O'Neill
Membre depuis le 08/04/2015
501 Réputation
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,005
