Aller au contenu principal
Sony Cyber-shot DSC-P100 Camera Lens Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: étape 1, image 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: étape 1, image 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: étape 1, image 3 de 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 2, image 1 de 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 3, image 1 de 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 4, image 2 de 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: étape 5, image 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: étape 5, image 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: étape 5, image 3 de 3
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 6, image 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 6, image 2 de 2
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: étape 7, image 1 de 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: étape 7, image 2 de 2
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 8, image 1 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 8, image 2 de 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 8, image 3 de 3
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: étape 9, image 1 de 1
    • The lens is now successfully removed from the camera.
Katie McCraw
Membre depuis le 03/09/12
191 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Spring 2012 Membre de l'équipe Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 membres
14 tutoriels rédigés
Un commentaire
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 2,634
