Aller au contenu principal
Sony Cyber-shot DSC-P52 Lens Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-P52 Lens Replacement, Outer Case: étape 1, image 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Lens Replacement: étape 2, image 1 de 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Lens Replacement: étape 3, image 1 de 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Lens Replacement: étape 4, image 1 de 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Lens Replacement: étape 5, image 1 de 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Lens Replacement: étape 6, image 1 de 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Lens Replacement: étape 7, image 1 de 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Lens Replacement, Lens: étape 8, image 1 de 1
    • Remove the two additional screws on the back of the lens.
  9. Sony Cyber-shot DSC-P52 Lens Replacement: étape 9, image 1 de 1
    • Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
  10. Sony Cyber-shot DSC-P52 Lens Replacement: étape 10, image 1 de 1
    • Remove the motherboard and the flash from the rest of the hardware.
  11. Sony Cyber-shot DSC-P52 Lens Replacement: étape 11, image 1 de 1
    • Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
  12. Sony Cyber-shot DSC-P52 Lens Replacement: étape 12, image 1 de 1
    • Remove the three screws shown to separate the lens from the viewfinder.
  13. Sony Cyber-shot DSC-P52 Lens Replacement: étape 13, image 1 de 1
    • Purchase a new viewfinder.
    • Repeat the previous steps in reverse order to rebuild.
Kari Johnson
Membre depuis le 01/10/11
127 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-43, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 1,331
