Aller au contenu principal
Introduction
If you are confident that your motherboard needs to be replaced, and have a replacement motherboard, then follow this guide.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  6. Open the case as shown.
    • Open the case as shown.
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Remove all six screws on the front side of the motherboard circled in the picture.
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  10. Remove the cable on the back side of the motherboard.
    • Remove the cable on the back side of the motherboard.
  11. Detach the ribbon cables shown.
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  12. The motherboard is now free, and ready to be replaced by a new one.
    • The motherboard is now free, and ready to be replaced by a new one.
Trevor
Membre depuis le 20/01/2011
277 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-43, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 911
