Aller au contenu principal
Sony Cyber-shot DSC-P52 Outer Case Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-P52 Outer Case Replacement, Outer Case: étape 1, image 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 2, image 1 de 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 3, image 1 de 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 4, image 1 de 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 5, image 1 de 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 6, image 1 de 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Outer Case Replacement: étape 7, image 1 de 1
    • Pull the ribbon cable out.
Trevor
Membre depuis le 01/20/11
295 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-43, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 583
