Pièces
Aucune pièce nécessaire.
  1. Slide the battery latch down the side of the camera with your hands.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Unlatch the clip over the battery.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
    • Remove the battery from the camera.
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
    • Then, pull the front case away from the rest of the camera.
    • After the casing is removed, the camera should look as shown.
Jenna Crawford
Membre depuis le 09/04/2012
29 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-25, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 671
