Pièces
Aucune pièce nécessaire.
  1. Slide the battery latch down the side of the camera with your hands.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Unlatch the clip over the battery.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Remove the battery from the camera. Remove the battery from the camera.
    • Remove the battery from the camera.
  4. Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver. Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  6. Once the screws are removed, slowly remove the back casing from the rest of the camera. Once the screws are removed, slowly remove the back casing from the rest of the camera.
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  7. Then, pull the front case away from the rest of the camera. Then, pull the front case away from the rest of the camera.
    • Then, pull the front case away from the rest of the camera.
  8. After the casing is removed, the camera should look as shown.
    • After the casing is removed, the camera should look as shown.
  9. Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
    • Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
  10. Pull off the pieces of casing located on either side of the top button of the camera.
    • Pull off the pieces of casing located on either side of the top button of the camera.
    • Both of the two pieces should slide off very easily. Do not force them off.
  11. Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
    • Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
Andrew Forster
Membre depuis le 16/04/2012
9 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-25, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 602
