Aller au contenu principal
Sony Cyber-shot DSC-T9 LCD Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-T9 LCD Replacement, Battery: étape 1, image 1 de 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 LCD Replacement: étape 2, image 1 de 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: étape 3, image 1 de 3 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: étape 3, image 2 de 3 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: étape 3, image 3 de 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 LCD Replacement: étape 4, image 1 de 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 LCD Replacement: étape 5, image 1 de 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 LCD Replacement: étape 6, image 1 de 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 LCD Replacement, Back Cover: étape 7, image 1 de 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 LCD Replacement: étape 8, image 1 de 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 LCD Replacement: étape 9, image 1 de 3 Sony Cyber-shot DSC-T9 LCD Replacement: étape 9, image 2 de 3 Sony Cyber-shot DSC-T9 LCD Replacement: étape 9, image 3 de 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 LCD Replacement: étape 10, image 1 de 3 Sony Cyber-shot DSC-T9 LCD Replacement: étape 10, image 2 de 3 Sony Cyber-shot DSC-T9 LCD Replacement: étape 10, image 3 de 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 LCD Replacement: étape 11, image 1 de 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 LCD Replacement: étape 12, image 1 de 1
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 LCD Replacement, LCD: étape 13, image 1 de 1
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 LCD Replacement: étape 14, image 1 de 1
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 LCD Replacement: étape 15, image 1 de 2 Sony Cyber-shot DSC-T9 LCD Replacement: étape 15, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 LCD Replacement: étape 16, image 1 de 2 Sony Cyber-shot DSC-T9 LCD Replacement: étape 16, image 2 de 2
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 LCD Replacement: étape 17, image 1 de 1
    • The LCD is now removed from the camera.
Stephannie Allen
Membre depuis le 03/11/13
255 Réputation
10 tutoriels rédigés
Équipe
Clemson, Team 13-1, Benson Spring 2013 Membre de l'équipe Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 37
Total : 1,252
