Aller au contenu principal
Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Battery: étape 1, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 2, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 2, image 2 de 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Back Case: étape 3, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Back Case: étape 3, image 2 de 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 4, image 2 de 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 5, image 1 de 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 6, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 6, image 2 de 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Front Case: étape 7, image 1 de 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 8, image 1 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 8, image 2 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 8, image 3 de 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Lens: étape 9, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Lens: étape 9, image 2 de 2
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 10, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 10, image 2 de 2
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Motherboard - First Half: étape 11, image 1 de 1
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 12, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 12, image 2 de 2
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 13, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 13, image 2 de 2
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: étape 14, image 1 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: étape 14, image 2 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: étape 14, image 3 de 3
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 15, image 1 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 15, image 2 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 15, image 3 de 3
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 16, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 16, image 2 de 2
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
  17. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Flash Assembly: étape 17, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Flash Assembly: étape 17, image 2 de 2
    • Verify that the orange cables from the top piece are removed from the motherboard.
    • Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
    • Pull the top off slowly and with caution. It is still slightly attached and may need a little force.
  18. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 18, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 18, image 2 de 2
    • Slowly twist out the flash assembly.
    • It is attached to the hinge so a little force is necessary.
  19. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Motherboard - Second Half: étape 19, image 1 de 1
    • Verify the red, white, and black cables are still attached to the camera.
    • Remove the screw using a Phillips #00 Screwdriver near the AV port
  20. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 20, image 1 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 20, image 2 de 3 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 20, image 3 de 3
    • Remove the bottom part of the camera (where the battery is inserted into).
    • This should detach the rest into two pieces. Place the other aside.
  21. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 21, image 1 de 2 Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: étape 21, image 2 de 2
    • To remove the crimps, use the spudger to push into gold part of the crimp and pull the wire out gently.
    • Careful not to break the crimps from the wires.
    • Remove the motherboard from the camera.
Andrew Carter
Membre depuis le 10/11/10
202 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-20, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 membres
18 tutoriels rédigés
Un commentaire
Si I' étais une forme d'objet technique, il me plairait d'être ainsi démonté-remonté.
Mais I ne suis qu'une dite forme de Grand mammifère placentaire respirant en dite basse couche atmosphérique planétaire.
I ne sais ce qu'est l'Intelligence, mais nonobstant que de dite finesse dans ces dites activités anatomiques-physiologiques explicatives.
Merci
Christian
Christian Lecoq - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 5,375
