Introduction
Does your door have an issue closing fully? Is your door damaged? It is time to replace it! This guide will show you all the steps required to replace your camera door. It is simple and a good DIY project. Save your money and fix your camera yourself.
make sure your door slider tab is in good shape.  If the tab is damaged you will need a door replacement.
  • make sure your door slider tab is in good shape. If the tab is damaged you will need a door replacement.
  • make sure your tab notches are in good shape. If there is a problem with the notches then you will need to replace the front housing cover of the unit.
  • If your door closes but looks like the unit in the 3rd picture then your door is either bent and damaged or the unit may not be assembled properly.
Ajouter un commentaire
Remove 6 external screws from the casing.  They are all the same size. I recommend using Phillips screwdriver size PH000
  • Remove 6 external screws from the casing. They are all the same size. I recommend using Phillips screwdriver size PH000
  • Remove the rear casing. You may need a spudger to release the tab. The tab is a depression style tab
  • remove side panels
  • Remove side panels and then remove front cover
  • Remove door rod
  • Remove door assembly and replace with new door. Reverse process to assemble unit
  • There is a little hole shown in the picture where the wire spring goes into.. make sure the wire spring is inserted into that hole or your door will not function.
Sales Cameraparts4you
Membre depuis le 01/07/2016
2 157 Réputation
18 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5
