Aller au contenu principal
Introduction
Once you have removed the cover the capacitor (a black cylinder that has 330v capacity) will be attached to the circuit board by a thin ribbon. Be careful with the ribbon.
Pièces
Aucune pièce spécifiée.
  1. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: étape 1, image 1 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: étape 1, image 2 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: étape 1, image 3 de 3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 2, image 1 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 2, image 2 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 2, image 3 de 3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 3, image 1 de 2 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 3, image 2 de 2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 4, image 2 de 2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 5, image 1 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 5, image 2 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: étape 5, image 3 de 3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: étape 6, image 1 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: étape 6, image 2 de 3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: étape 6, image 3 de 3
    • Lift the capacitor out and gently pull it away from the control board to unplug the ribbon attached to the side of the circuit board. Be careful not to bend the ribbon.
Douglas Howe
Membre depuis le 08/01/2015
474 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 9-4, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 600
