Aller au contenu principal
Sony Cyber-shot DSC-WX100 Flash Bulb Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Battery: étape 1, image 1 de 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 2, image 1 de 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: étape 3, image 1 de 3 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: étape 3, image 2 de 3 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: étape 3, image 3 de 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 5, image 1 de 2 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift so the plate is high enough that the marked bump is not holding it in place.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 7, image 1 de 3 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 7, image 2 de 3 Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 7, image 3 de 3
    • Peel back the copper cover and black tape from the motherboard to reveal the connection port.
    • Using the plastic opening tool, release the black bar on the connection port so that the bar is vertical.
    • Pull the tab out.
  7. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 8, image 1 de 1
    • Pull back on the case, then pull the entire tab out from the case.
  8. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: étape 9, image 1 de 1
    • Solder the 4 marked nodes and the remove the flash bulb from the sheet.
    • For help on soldering, refer to this Guide.
Matthew
Membre depuis le 03/18/15
583 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 1-9, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 789
