Aller au contenu principal
Sony Cyber-shot DSC-WX100 LCD Screen Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 2, image 1 de 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: étape 3, image 1 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: étape 3, image 2 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: étape 3, image 3 de 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 5, image 1 de 2 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so the plate is high enough so that the marked bump is not holding it in place.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help please watch the video.
  6. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 7, image 1 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 7, image 2 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 7, image 3 de 3
    • Remove this screw (1mm) with a Phillips #000 Screwdriver.
    • Gently lift the LCD from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 8, image 1 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 8, image 2 de 3 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: étape 8, image 3 de 3
    • Use the plastic opening tool to pry the black bar upwards.
    • Pull the LCD screen from out of the slot.
Peter Prins
Membre depuis le 03/19/15
262 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-9, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 membres
6 tutoriels rédigés
Un commentaire
be careful with capacitor !!! i touched it 5-10 minutes after battery was removed and felt electricity in my chest, ears… be careful :D
k.bilius - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 1,310
