Introduction
This guide allows one to remove the lens unit from the camera. Thus is can then be replaced by a new one.
Ce dont vous avez besoin
Remove all of the 1mm screws using a Philips #000 Screwdriver.
Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
Un commentaire
could i also replace the lens of my wx220 using these instructions?
