Aller au contenu principal
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: étape 1, image 1 de 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: étape 2, image 1 de 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: étape 3, image 1 de 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: étape 3, image 2 de 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: étape 3, image 3 de 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: étape 5, image 1 de 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to gently release the two indicated tabs.
2 autres ont terminé cette réparation.
Matthew
Membre depuis le 03/18/15
583 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 1-9, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 membres
6 tutoriels rédigés
Un commentaire
Where I can buy the Outer Casing..¿??
ING CHARLY - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 28
Total : 854
