Aller au contenu principal
Sony Cyber-shot DSC-WX220 Flash Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-WX220 Flash Replacement, Battery: étape 1, image 1 de 1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 2, image 1 de 2 Sony Cyber-shot DSC-WX220 Flash Replacement: étape 2, image 2 de 2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: étape 3, image 1 de 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: étape 3, image 2 de 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: étape 3, image 3 de 3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-WX220 Flash Replacement: étape 4, image 2 de 2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Flash Replacement, Flash Assembly: étape 5, image 1 de 1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 6, image 1 de 1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 7, image 1 de 1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 8, image 1 de 1
    • Pull the capacitor out of the shell.
    • Be careful not to shock yourself on the capacitor(metal components on the top)
  9. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 9, image 1 de 1
    • Unpin the flash assembly.
  10. Sony Cyber-shot DSC-WX220 Flash Replacement: étape 10, image 1 de 1
    • Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
Kate Glazer
Membre depuis le 03/20/18
621 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S6-G3, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 544
