Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony DSC-RX10M3 Back and Right Panel Replacement
Ce dont vous avez besoin
  1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: étape 1, image 1 de 1
    • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 2, image 1 de 3 Sony DSC-RX10M3 Back and Right Panel Replacement: étape 2, image 2 de 3 Sony DSC-RX10M3 Back and Right Panel Replacement: étape 2, image 3 de 3
    • Remove the battery located at the bottom of the device.
    Demander à FixBot
  3. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: étape 3, image 1 de 1
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
    Demander à FixBot
  4. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 4, image 1 de 2 Sony DSC-RX10M3 Back and Right Panel Replacement: étape 4, image 2 de 2
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
    Demander à FixBot
  5. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 5, image 1 de 2 Sony DSC-RX10M3 Back and Right Panel Replacement: étape 5, image 2 de 2
    • Gently pull off the plastic eye guard.
    Demander à FixBot
  6. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 6, image 1 de 2 Sony DSC-RX10M3 Back and Right Panel Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
    Demander à FixBot
  7. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
    Demander à FixBot
  8. Sony DSC-RX10M3 Back and Right Panel Replacement: étape 8, image 1 de 1
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
    Demander à FixBot
3 autres ont terminé cette réparation.
Salman Hersi
Membre depuis le 01/14/20
339 Réputation
2 tutoriels rédigés
Équipe
York University, Team S4-G4, Woodhouse Winter 2020 Membre de l'équipe York University, Team S4-G4, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S4G4
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 64
Total : 1,914
