Introduction
In order to access the internals of the device, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced.
Pièces
Aucune pièce nécessaire.
  1. Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Punch through the warranty sticker with the spudger and remove the screw underneath.
  2. Remove the rubber feet with the screwdriver.
    • Remove the rubber feet with the screwdriver.
    • Remove the screws that the rubber feet were covering.
    • Lift up the cover gently.
    • The tray is still connected to the base with wires.
    • Remove the wires with tweezers by gently pulling on the base they are attached to.
Rogelio Garcia
Membre depuis le 20/01/2012
10 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-21, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,269
