Aller au contenu principal
Introduction
If the device is on but nothing shows up on the screen, the screen may need to be replaced.
Pièces
Aucune pièce spécifiée.
  1. Use your hand to remove the small back cover. Use your hand to remove the small back cover.
    • Use your hand to remove the small back cover.
  2. Remove the two 0.473" pan head screws.
    • Remove the two 0.473" pan head screws.
  3. The screen should now detach from the main device.
    • The screen should now detach from the main device.
    • The screen will still be connected by the wires.
  4. Remove the wires attached to the white base by using the tweezers. Remove the wires attached to the white base by using the tweezers.
    • Remove the wires attached to the white base by using the tweezers.
  5. Do the same with the wires attached to the black base. Do the same with the wires attached to the black base.
    • Do the same with the wires attached to the black base.
  6. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  7. The screen should now be completely separated from the main device.
    • The screen should now be completely separated from the main device.
  8. Remove the four rubber feet and the screws beneath.
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  9. Using the spudger, separate the top and bottom covers.
    • Using the spudger, separate the top and bottom covers.
  10. Identify the gray back of the screen.
    • Identify the gray back of the screen.
  11. Remove the screws.
    • Remove the screws.
  12. Remove the metal plates.
    • Remove the metal plates.
  13. Using spudger, push the lock clips to unlock the ribbon cable. Using tweezers, pull the connector loose.
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  14. Place your hand on the front of the screen and push upwards. Place your hand on the front of the screen and push upwards.
    • Place your hand on the front of the screen and push upwards.
2 autre(s) ont terminé cette réparation.
Oliver Woolsoncroft
Membre depuis le 20/01/2012
69 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-21, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 5
Total : 2,269
