Aller au contenu principal
Sony DVP-NS325 Optical Drive Replacement
Ce dont vous avez besoin
  1. Sony DVP-NS325 Optical Drive Replacement, Outer Case: étape 1, image 1 de 3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: étape 1, image 2 de 3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: étape 1, image 3 de 3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Optical Drive Replacement: étape 2, image 1 de 3 Sony DVP-NS325 Optical Drive Replacement: étape 2, image 2 de 3 Sony DVP-NS325 Optical Drive Replacement: étape 2, image 3 de 3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Optical Drive Replacement: étape 3, image 1 de 1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Optical Drive Replacement, Optical Drive: étape 4, image 1 de 3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: étape 4, image 2 de 3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: étape 4, image 3 de 3
    • The Location of the three screws holding the CD reader in place.
  5. Sony DVP-NS325 Optical Drive Replacement: étape 5, image 1 de 1
    • Use a Phillips screwdriver to remove all three screws holding the CD reader in position.
    • Two screws not shown.
  6. Sony DVP-NS325 Optical Drive Replacement: étape 6, image 1 de 2 Sony DVP-NS325 Optical Drive Replacement: étape 6, image 2 de 2
    • Disconnect all of the optical drive motherboard connections.
  7. Sony DVP-NS325 Optical Drive Replacement: étape 7, image 1 de 3 Sony DVP-NS325 Optical Drive Replacement: étape 7, image 2 de 3 Sony DVP-NS325 Optical Drive Replacement: étape 7, image 3 de 3
    • Lift the four retention clips holding the face of the DVD player in place.
    • Two clips are not shown, left and bottom right side clips.
  8. Sony DVP-NS325 Optical Drive Replacement: étape 8, image 1 de 1
    • Remove the front face of the DVD player by pulling it away from the device.
  9. Sony DVP-NS325 Optical Drive Replacement: étape 9, image 1 de 1
    • Remove the optical drive.
isaiah davila
Membre depuis le 09/13/23
469 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 32
