Aller au contenu principal
Sony DVP-NS325 Power Supply Board Replacement
Ce dont vous avez besoin
  1. Sony DVP-NS325 Power Supply Board Replacement, Outer Case: étape 1, image 1 de 3 Sony DVP-NS325 Power Supply Board Replacement, Outer Case: étape 1, image 2 de 3 Sony DVP-NS325 Power Supply Board Replacement, Outer Case: étape 1, image 3 de 3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Power Supply Board Replacement: étape 2, image 1 de 3 Sony DVP-NS325 Power Supply Board Replacement: étape 2, image 2 de 3 Sony DVP-NS325 Power Supply Board Replacement: étape 2, image 3 de 3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Power Supply Board Replacement: étape 3, image 1 de 1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Power Supply Board Replacement, Power Cable: étape 4, image 1 de 2 Sony DVP-NS325 Power Supply Board Replacement, Power Cable: étape 4, image 2 de 2
    • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
  5. Sony DVP-NS325 Power Supply Board Replacement: étape 5, image 1 de 2 Sony DVP-NS325 Power Supply Board Replacement: étape 5, image 2 de 2
    • Using a finger, press down on the clip to remove the connector for the cable.
  6. Sony DVP-NS325 Power Supply Board Replacement: étape 6, image 1 de 1
    • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
  7. Sony DVP-NS325 Power Supply Board Replacement: étape 7, image 1 de 1
    • Pull the cable out of the case to fully replace the cable.
  8. Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: étape 8, image 1 de 2 Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: étape 8, image 2 de 2
    • Remove the wire connected to the motherboard by pulling the wire upwards.
    • Move the black holder piece out of the way in order to fully remove the wire from the area.
  9. Sony DVP-NS325 Power Supply Board Replacement: étape 9, image 1 de 1
    • Using a Phillips screwdriver, remove the four screws holding the motherboard in place.
    • There are three screws not shown all located on the corners of the motherboard.
  10. Sony DVP-NS325 Power Supply Board Replacement: étape 10, image 1 de 1
    • Remove the power supply board.
isaiah davila
Membre depuis le 09/13/23
469 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 10
Total : 58
