Aller au contenu principal
Sony Dream Machine ICF-C180 Speaker Replacement
Ce dont vous avez besoin
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: étape 1, image 1 de 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: étape 1, image 2 de 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: étape 2, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 2, image 2 de 2
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: étape 3, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 3, image 2 de 2
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: étape 4, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 4, image 2 de 2
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: étape 5, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 5, image 2 de 2
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: étape 6, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 6, image 2 de 2
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: étape 7, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 7, image 2 de 2
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: étape 8, image 1 de 2 Sony Dream Machine ICF-C180 Speaker Replacement: étape 8, image 2 de 2
    • Pull the speaker upward to remove it.
Caleb John
Membre depuis le 05/31/16
101 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
HEY! that's moderately adequate...
Caleb John - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 521
