Aller au contenu principal
Introduction
This guide will help you to remove the keypad from your Sony Ericsson T68i.
Pièces
Aucune pièce spécifiée.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  4. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Tim Dascomb
Membre depuis le 13/04/2010
135 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 26-34, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 membres
13 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,989
