Aller au contenu principal
Introduction
This guide will assist you in removing the microphone from your Sony Ericsson T68i.
Pièces
Aucune pièce spécifiée.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  6. Next remove the circuit board and screen from the device. Use your T6 to remove the 4 screws holding the cover on. Use your T6 to remove the 4 screws holding the cover on.
    • Next remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws holding the cover on.
  7. The board and screen should just pop out at this point. The board and screen should just pop out at this point. The board and screen should just pop out at this point.
    • The board and screen should just pop out at this point.
  8. The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool. The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
    • The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
Tim Dascomb
Membre depuis le 13/04/2010
135 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 26-34, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 membres
13 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 2,024
