Aller au contenu principal
Sony Ericsson W350a Keypad Replacement
Ce dont vous avez besoin
  1. Sony Ericsson W350a Keypad Replacement, Flip Cover: étape 1, image 1 de 1
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
  2. Sony Ericsson W350a Keypad Replacement: étape 2, image 1 de 1
    • Remove the cover with a slight twisting motion.
  3. Sony Ericsson W350a Keypad Replacement, Battery: étape 3, image 1 de 2 Sony Ericsson W350a Keypad Replacement, Battery: étape 3, image 2 de 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  4. Sony Ericsson W350a Keypad Replacement: étape 4, image 1 de 3 Sony Ericsson W350a Keypad Replacement: étape 4, image 2 de 3 Sony Ericsson W350a Keypad Replacement: étape 4, image 3 de 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  5. Sony Ericsson W350a Keypad Replacement, Speaker: étape 5, image 1 de 2 Sony Ericsson W350a Keypad Replacement, Speaker: étape 5, image 2 de 2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  6. Sony Ericsson W350a Keypad Replacement: étape 6, image 1 de 1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Keypad Replacement: étape 7, image 1 de 1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  8. Sony Ericsson W350a Keypad Replacement: étape 8, image 1 de 1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  9. Sony Ericsson W350a Keypad Replacement: étape 9, image 1 de 2 Sony Ericsson W350a Keypad Replacement: étape 9, image 2 de 2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  10. Sony Ericsson W350a Keypad Replacement: étape 10, image 1 de 2 Sony Ericsson W350a Keypad Replacement: étape 10, image 2 de 2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
  11. Sony Ericsson W350a Keypad Replacement, Keypad: étape 11, image 1 de 3 Sony Ericsson W350a Keypad Replacement, Keypad: étape 11, image 2 de 3 Sony Ericsson W350a Keypad Replacement, Keypad: étape 11, image 3 de 3
    • Disconnect the ribbon cable from its connection until the keypad "pops" off.
    • Remove the keypad from the phone.
Ldellos
Membre depuis le 03/12/12
112 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 1-4, Benson Spring 2012 Membre de l'équipe Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,270
