Ce dont vous avez besoin
Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
Remove the two 6.35mm screws with a Torx T6 screwdriver.
Peel the rubber keys away from their backing. Do not slide them off.
Set them aside.
Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
2 autres ont terminé cette réparation.
