Aller au contenu principal
Sony Ericsson Xperia Play Digitizer Replacement
Ce dont vous avez besoin
  1. Sony Ericsson Xperia Play Digitizer Replacement, Digitizer: étape 1, image 1 de 1
    • Remove the 6 silver torx screws marked in red
  2. Sony Ericsson Xperia Play Digitizer Replacement: étape 2, image 1 de 1
    • Remove the 7 black torx screws marked in yellow.
  3. Sony Ericsson Xperia Play Digitizer Replacement: étape 3, image 1 de 1
    • Using a plastic prying tool, go around the outside of the phone releasing the plastic clips.
  4. Sony Ericsson Xperia Play Digitizer Replacement: étape 4, image 1 de 1
    • Remove the plastic housing revealing the motherboard
    • Remove the two Phillips screws.
  5. Sony Ericsson Xperia Play Digitizer Replacement: étape 5, image 1 de 1
    • Remove the headphone jack by carefully moving the dark plastic clip on the connector to 90 degrees
  6. Sony Ericsson Xperia Play Digitizer Replacement: étape 6, image 1 de 1
    • Slide the phone to the open position
  7. Sony Ericsson Xperia Play Digitizer Replacement: étape 7, image 1 de 1
    • Remove the display connector marked in orange using a plastic spudger to pry it upwards
    • Remove the connector for the front buttons by prising the retaining clip to 90 degrees
  8. Sony Ericsson Xperia Play Digitizer Replacement: étape 8, image 1 de 1
    • Remove motherboard
  9. Sony Ericsson Xperia Play Digitizer Replacement: étape 9, image 1 de 1
    • Remove the buttons from the phone
  10. Sony Ericsson Xperia Play Digitizer Replacement: étape 10, image 1 de 1
    • Remove the three Phillips screws.
  11. Sony Ericsson Xperia Play Digitizer Replacement: étape 11, image 1 de 1
    • Slide the metal frame across revealing the last screw . Make sure to keep the plastic cover after removing the screw
    • Disconnect the digitizer cable
  12. Sony Ericsson Xperia Play Digitizer Replacement: étape 12, image 1 de 1
    • Insert a plastic spudger around the edge of the frame and take the lcd assembely from the glass
    • Using a heat gun heat around the edges of the glass to soften the glue, and use your prying tool between the glass and the frame to take the glass off.
16 autres ont terminé cette réparation.
Kris James
Membre depuis le 01/27/12
603 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 31,334
