Aller au contenu principal
Sony Ericsson Xperia Pro MK16A Power Button Replacement
Ce dont vous avez besoin
  1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: étape 1, image 1 de 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: étape 1, image 2 de 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: étape 1, image 3 de 3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Removing the Battery: étape 2, image 1 de 1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: étape 3, image 1 de 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: étape 3, image 2 de 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: étape 3, image 3 de 3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Back Case: étape 4, image 1 de 1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: étape 5, image 1 de 2 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: étape 5, image 2 de 2
    • When the inner back cover is off, locate and remove the power button.
John Emery
Membre depuis le 10/16/14
65 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 795
