Aller au contenu principal
Sony Ericsson Z500a Keypad Replacement
Ce dont vous avez besoin
  1. Sony Ericsson Z500a Keypad Replacement, Keypad: étape 1, image 1 de 3 Sony Ericsson Z500a Keypad Replacement, Keypad: étape 1, image 2 de 3 Sony Ericsson Z500a Keypad Replacement, Keypad: étape 1, image 3 de 3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Keypad Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Keypad Replacement: étape 3, image 1 de 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
Jory Benitez
Membre depuis le 04/16/10
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-12, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 15
Total : 2,732
