Aller au contenu principal
Sony Ericsson s710a Main Interface Buttons Replacement
Ce dont vous avez besoin
  1. Sony Ericsson s710a Main Interface Buttons Replacement, Battery: étape 1, image 1 de 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Main Interface Buttons Replacement: étape 2, image 1 de 1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Main Interface Buttons Replacement: étape 3, image 1 de 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Main Interface Buttons Replacement, LCD Screen: étape 4, image 1 de 1
    • Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a Main Interface Buttons Replacement: étape 5, image 1 de 1
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a Main Interface Buttons Replacement: étape 6, image 1 de 1
    • Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
  7. Sony Ericsson s710a Main Interface Buttons Replacement: étape 7, image 1 de 1
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a Main Interface Buttons Replacement: étape 8, image 1 de 1
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a Main Interface Buttons Replacement: étape 9, image 1 de 1
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a Main Interface Buttons Replacement: étape 10, image 1 de 1
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
  11. Sony Ericsson s710a Main Interface Buttons Replacement: étape 11, image 1 de 1
    • On the rotational assembly remove the following screws:
    • Four 3 mm screws
    • Two 2.3 mm screws
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a Main Interface Buttons Replacement: étape 12, image 1 de 1
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector for reassembly.
  13. Sony Ericsson s710a Main Interface Buttons Replacement: étape 13, image 1 de 1
    • Remove the plastic cover on the back of the phone using an iFixit opening tool.
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
  14. Sony Ericsson s710a Main Interface Buttons Replacement: étape 14, image 1 de 1
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a Main Interface Buttons Replacement: étape 15, image 1 de 1
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
  16. Sony Ericsson s710a Main Interface Buttons Replacement, Main Interface Buttons: étape 16, image 1 de 1
    • Remove the button and pad assembly as shown.
    • If desired, these items can now be cleaned or replaced.
Alexander
Membre depuis le 10/29/11
75 Réputation
4 tutoriels rédigés
Équipe
University of Maryland, Team 1-1, Calloway Fall 2011 Membre de l'équipe University of Maryland, Team 1-1, Calloway Fall 2011
UMD-CALLOWAY-F11S1G1
3 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 954
