Aller au contenu principal
Sony Ericsson xPeria Active Camera Replacement
Ce dont vous avez besoin
  1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: étape 1, image 1 de 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: étape 1, image 2 de 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: étape 1, image 3 de 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: étape 2, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: étape 2, image 2 de 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: étape 3, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Remove the battery: étape 3, image 2 de 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: étape 4, image 1 de 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: étape 5, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: étape 5, image 2 de 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: étape 6, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: étape 6, image 2 de 2
    • Unplug the plug from the motherboard.
  7. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: étape 7, image 1 de 1
    • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
  8. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: étape 8, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: étape 8, image 2 de 2
    • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
  9. Sony Ericsson xPeria Active Camera Replacement: étape 9, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
  10. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: étape 10, image 1 de 2 Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: étape 10, image 2 de 2
    • Pull the camera out through the front of the motherboard.
Alex Tobin
Membre depuis le 10/06/14
406 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-5, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 773
