Introduction
The speaker of a phone can go bad for a number of reasons. The most common reason for a faulty speaker is water damage. However, a speaker may go bad due to a faulty connection or faulty manufacturing.
Open the flaps and remove the back cover using the plastic opening device.
  • Open the flaps and remove the back cover using the plastic opening device.
Ajouter un commentaire
Remove the battery shield with the plastic opening device.
  • Remove the battery shield with the plastic opening device.
  • Remove the battery.
  • Unscrew the 5mm screws with the T5 head.
  • Unscrew the 6mm screw with the T6 head.
  • Remove the black cover with the plastic opening tool.
  • Remove the headphone jack from its slot.
  • Carefully pry the power cable away from the motherboard.
  • Pry the motherboard out of the case.
  • Remove the power cable from the backside of the motherboard.
  • The speaker can be seen in the top middle area on the reverse of the screen.
  • Use the plastic opening tool to carefully pry the speaker away from the phone.
2 autre(s) ont terminé cette réparation.
Daniel
Membre depuis le 13/10/2014
415 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-5, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 636
