Aller au contenu principal
Sony Ericsson xPeria Active Speaker Replacement
Ce dont vous avez besoin
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: étape 1, image 1 de 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: étape 1, image 2 de 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: étape 1, image 3 de 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: étape 2, image 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: étape 2, image 2 de 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: étape 3, image 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: étape 3, image 2 de 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: étape 4, image 1 de 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: étape 5, image 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: étape 5, image 2 de 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: étape 6, image 1 de 2 Sony Ericsson xPeria Active Speaker Replacement, Speaker: étape 6, image 2 de 2
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: étape 7, image 1 de 1
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: étape 8, image 1 de 1
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: étape 9, image 1 de 1
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: étape 10, image 1 de 1
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
2 autres ont terminé cette réparation.
Daniel
Membre depuis le 10/13/14
437 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-5, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 872
