Aller au contenu principal
Introduction
This guide shows how to remove the Keypad.
Pièces
Aucune pièce spécifiée.
  1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: étape 1, image 1 de 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Keypad Replacement, Battery: étape 2, image 1 de 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Keypad Replacement, Sim Card: étape 3, image 1 de 1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: étape 4, image 1 de 1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Keypad Replacement: étape 5, image 1 de 1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Keypad Replacement: étape 6, image 1 de 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Keypad Replacement, Motherboard: étape 7, image 1 de 1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Keypad Replacement: étape 8, image 1 de 1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Keypad Replacement: étape 9, image 1 de 1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Keypad Replacement, Keypad: étape 10, image 1 de 1
    • Using a plastic opening tool lift up the keypad to remove it.
Alex Serventi
Membre depuis le 07/10/2010
50 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 5-15, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,293
