Aller au contenu principal
Sony FDL-220R Watchman Antenna Replacement
Ce dont vous avez besoin
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: étape 1, image 1 de 2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: étape 1, image 2 de 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: étape 2, image 1 de 2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: étape 2, image 2 de 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: étape 3, image 1 de 2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: étape 3, image 2 de 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: étape 4, image 1 de 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: étape 4, image 2 de 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: étape 4, image 3 de 3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Sam Putnam
Membre depuis le 10/22/14
484 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-5, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 481
