Introduction
This guide will outline how to replace the Sony FDL-220R Watchman batteries and clean the battery contacts if they are corroded. Steps include basic disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver and a solution of warm water and baking soda.
Press down on the textured area and push towards the bottom of the device.
  • Press down on the textured area and push towards the bottom of the device.
  • Gently remove the battery cover.
  • Remove the three AA batteries.
Ajouter un commentaire
Inspect battery contacts for any signs of damage.
  • Inspect battery contacts for any signs of damage.
  • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  • Locate the five 5x11mm screws surrounding the battery compartment.
  • Remove screws with a Phillips #00 screwdriver.
  • Grasp the entire back half of the Watchman's casing.
  • Snap off casing from the bottom of the device.
  • Gently pull off entire back casing.
  • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  • Inspect the two small springs on the back of the battery compartment.
  • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Sam Putnam
Membre depuis le 22/10/2014
484 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-5, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 224
