Aller au contenu principal
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
Ce dont vous avez besoin
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: étape 1, image 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: étape 1, image 2 de 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: étape 2, image 1 de 1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: étape 3, image 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: étape 3, image 2 de 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: étape 4, image 1 de 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: étape 4, image 2 de 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: étape 5, image 1 de 1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Sam Putnam
Membre depuis le 10/22/14
484 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-5, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 506
