Aller au contenu principal
Sony FDL-220R Watchman Speaker Replacement
Ce dont vous avez besoin
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: étape 1, image 1 de 2 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: étape 1, image 2 de 2
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: étape 2, image 1 de 2 Sony FDL-220R Watchman Speaker Replacement, Remove screws: étape 2, image 2 de 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: étape 3, image 1 de 2 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: étape 3, image 2 de 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: étape 4, image 1 de 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: étape 4, image 2 de 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: étape 4, image 3 de 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: étape 5, image 1 de 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: étape 5, image 2 de 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: étape 5, image 3 de 3
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
Sam Putnam
Membre depuis le 10/22/14
484 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-5, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 284
