Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4
Ce dont vous avez besoin
  1. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, Controller: étape 1, image 1 de 1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 2, image 1 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 2, image 2 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 2, image 3 de 3
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
    Demander à FixBot
  3. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 3, image 1 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 3, image 2 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 3, image 3 de 3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
    Demander à FixBot
  4. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, Disassembling DualShock 4 Motherboard Assembly: étape 4, image 1 de 1
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
    Demander à FixBot
  5. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 5, image 1 de 2 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 5, image 2 de 2
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
    Demander à FixBot
  6. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 6, image 1 de 2 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4: étape 6, image 2 de 2
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
    Demander à FixBot
  7. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, Disassembly Complete: étape 7, image 1 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, Disassembly Complete: étape 7, image 2 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, Disassembly Complete: étape 7, image 3 de 3
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
    Demander à FixBot
  8. Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, De-Solder Worn Potentiometers: étape 8, image 1 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, De-Solder Worn Potentiometers: étape 8, image 2 de 3 Sony Game Console Accessory L3 and R3 Potentiometer Replacement for PS3 & PS4, De-Solder Worn Potentiometers: étape 8, image 3 de 3
    • Note the Sixaxis conductive film connector is superior to the DualShock 3.
    • De-solder the four (4) potentiometer through hole mounts.
    • De-solder the six (6) potentiometer through hole joints.
    • De-solder the L3 and R3 button joints, then insert and solder the new potentiometers.
    • Note this mainboard asembly uses lead solder, likely 63/37 eutectic. A 80W soldering iron is strongly recommended for de-soldering and re-soldering operations, as solder tends to not easily flow with less heat transfer.
    • Also works on Dual Shock 4
    Demander à FixBot
7 autres ont terminé cette réparation.
DARKMATTER
Membre depuis le 07/10/14
257 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
I’ve been looking for “better” (longer lasting) potentiometers but cannot find any. With the rise in DIY controller mods, I don’t understand why better components don’t exist.
Robert Remington - Réponse Partager
get ones off ebay that r usa and metal spring not plastic
DARKMATTER - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 89
Total : 8,522
