Aller au contenu principal
Sony H.ear On 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Sony H.ear On 2 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: étape 2, image 1 de 2 Sony H.ear On 2 Motherboard Replacement: étape 2, image 2 de 2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: étape 3, image 1 de 3 Sony H.ear On 2 Motherboard Replacement: étape 3, image 2 de 3 Sony H.ear On 2 Motherboard Replacement: étape 3, image 3 de 3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see Comment souder et dessouder des connexions for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: étape 4, image 1 de 2 Sony H.ear On 2 Motherboard Replacement: étape 4, image 2 de 2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: étape 5, image 1 de 1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Michael Long
Membre depuis le 04/15/19
131 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S9-G11, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 membres
16 tutoriels rédigés
Un commentaire
where can i find a replacement motherboard for these headphones?
MTL - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 31
Total : 1,568
