Introduction
Occasionally, the laser eye will break or no longer move along the track. In this handycam, the laser eye is not replaceable by itself, but the laser bay may be swapped.
Outils
Pièces
Aucune pièce spécifiée.
Locate the battery pack which can be found on the back side of the camera below the viewfinder.
Push in the small button on the bottom of the camera, marked with the red circle, then slide the entire switch forward, marked with the yellow rectangle.
Remove the (6) 4.5mm screws from the bottom of the Sony Handycam that are marked with small circles.
Remove (1) 2.9mm screw from under the eye piece.
Remove (1) 2.9mm screw from above the eye piece.
Remove (4) copper strips from bellow the eye piece.
Pull off the eye piece assembly.
