Introduction
Can't record or capture moments with a cracked lens? This guide will take you through removing the outer casing and removal and replacement of the lens module.
Ce dont vous avez besoin
Unfasten the hand strap.
Use the blunt tweezers to unplug the red and black wire by pulling out and away.
Unplug the small ribbon wire.
Unscrew the two right three 3mm Philips screws.
To reassemble your device, follow these instructions in reverse order in addition to the HDD replacement guide.
