Introduction
Removing the LCD will be moderately difficult. Be careful to not damage any ribbons when removing them from their sockets.
Ce dont vous avez besoin
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Orient the camera such that the lens is facing to your left.
Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
Rotate the camera so that it is upright and the lens is pointed to your left.
Using your right hand to hold the screwdriver and your left to hold the camera, remove the single 5.5 mm Phillips #00 screw from on the top of the shutter assembly.
With the right side of the camera facing toward you, remove the single 5.5 mm Phillips #00 screw.
Rotate the LCD screen on its hinge +/- 90 degrees relative to the camera to expose the screws on the side of the LCD panel.
Remove the two 5.5 mm Phillips #00 screws.
3 autres ont terminé cette réparation.
