Aller au contenu principal
Sony ICF-C1iPMK2 Screen Replacement
Ce dont vous avez besoin
  1. Sony ICF-C1iPMK2 Screen Replacement, Screen: étape 1, image 1 de 3 Sony ICF-C1iPMK2 Screen Replacement, Screen: étape 1, image 2 de 3 Sony ICF-C1iPMK2 Screen Replacement, Screen: étape 1, image 3 de 3
    • Flip product over to see the back.
    • Remove the 1 cm Phillips #00 screws.
    • Use a plastic spudger to pry the back chassis off of the front.
  2. Sony ICF-C1iPMK2 Screen Replacement: étape 2, image 1 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 2, image 2 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 2, image 3 de 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Open up the back.
    • Carefully remove the ribbon cables by pulling them straight out of the port.
  3. Sony ICF-C1iPMK2 Screen Replacement: étape 3, image 1 de 2 Sony ICF-C1iPMK2 Screen Replacement: étape 3, image 2 de 2
    • Remove the power connector.
    • Remove the aux cable connector.
  4. Sony ICF-C1iPMK2 Screen Replacement: étape 4, image 1 de 1
    • Slide buttons off the front chassis
  5. Sony ICF-C1iPMK2 Screen Replacement: étape 5, image 1 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 5, image 2 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 5, image 3 de 3
    • Remove the 1 cm screws from the plastic speaker cover using Phillips #00 screwdriver.
    • Gently pull the speaker cable out.
  6. Sony ICF-C1iPMK2 Screen Replacement: étape 6, image 1 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 6, image 2 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 6, image 3 de 3
    • Remove the plastic speaker cover from the left side.
  7. Sony ICF-C1iPMK2 Screen Replacement: étape 7, image 1 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 7, image 2 de 3 Sony ICF-C1iPMK2 Screen Replacement: étape 7, image 3 de 3
    • Remove the two 1 cm Phillips #00 screws.
    • Carefully pull out the ribbon cable.
    • Slide the iPod dock out.
  8. Sony ICF-C1iPMK2 Screen Replacement: étape 8, image 1 de 1
    • Gently push down and pull the screen out.
2 autres ont terminé cette réparation.
KyndleGabel
Membre depuis le 09/15/23
530 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 12
Total : 131
