Aller au contenu principal
Sony MVC-FD200 LCD Display Screen Replacement
Ce dont vous avez besoin
  1. Sony MVC-FD200 LCD Display Screen Replacement, Battery: étape 1, image 1 de 1
    • Using your finger, slide the tab on the battery door up to release the battery latch.
  2. Sony MVC-FD200 LCD Display Screen Replacement: étape 2, image 1 de 1
    • Lift the battery door to reveal the battery compartment.
    • Push the gray lever to the left side to remove the battery.
    • If any other repairs are needed, make sure to carefully remove the battery to avoid any electric shock or short circuits during repairs.
  3. Sony MVC-FD200 LCD Display Screen Replacement, Back Cover: étape 3, image 1 de 1
    • Turn the camera so that the top is facing down towards the table.
    • Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
  4. Sony MVC-FD200 LCD Display Screen Replacement: étape 4, image 1 de 2 Sony MVC-FD200 LCD Display Screen Replacement: étape 4, image 2 de 2
    • Flip the camera on both sides and remove the rest of the screws with arrows facing towards them.
    • Remove the 2.0 mm screws with the Phillips #00 screwdriver for both sides of the camera.
  5. Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: étape 5, image 1 de 3 Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: étape 5, image 2 de 3 Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: étape 5, image 3 de 3
    • Detach the ribbon cable that connects the two halves of the device to split them apart.
    • Gently pry up the black plastic tab to slide out the ribbon cables.
    • Be gentle because this component is thin, but do not be afraid to damage the ribbon cable during removal. Add force progressively in small amounts.
  6. Sony MVC-FD200 LCD Display Screen Replacement: étape 6, image 1 de 1
    • Remove the six 2.0 mm screws which hold the motherboard in place using the Phillips #00 screwdriver.
  7. Sony MVC-FD200 LCD Display Screen Replacement: étape 7, image 1 de 1
    • Remove the four 2.0 mm screws which hold down the heat shield using the Phillips #00 screwdriver.
  8. Sony MVC-FD200 LCD Display Screen Replacement: étape 8, image 1 de 2 Sony MVC-FD200 LCD Display Screen Replacement: étape 8, image 2 de 2
    • The LCD display and the backlight which sits on top of it are displayed.
    • Push both components out.
Nathan Cordeiro
Membre depuis le 03/19/25
114 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-4, Rioux Spring 2025 Membre de l'équipe UMass Dartmouth, Team 1-4, Rioux Spring 2025
UMASSD-RIOUX-S25S1G4
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
I have a Mavica FD71, will this work about the same? (Pixels in the middle of the screen have started to die) I’ve been looking, but I can’t find a replacement lcd panel for my model, do the Mavica FD2000 and the FD71 use the same lcd panel?
Average AirPod User - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 15
Total : 220
