Aller au contenu principal
Sony NEX-5R Lens Mount Replacement
Ce dont vous avez besoin
  1. Sony NEX-5R Lens Mount Replacement, Lens Mount: étape 1, image 1 de 2 Sony NEX-5R Lens Mount Replacement, Lens Mount: étape 1, image 2 de 2
    • Hold lens and camera securely with two hands.
    • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
  2. Sony NEX-5R Lens Mount Replacement: étape 2, image 1 de 1
    • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
    • Make sure to keep track of these screws and not misplace them.
  3. Sony NEX-5R Lens Mount Replacement: étape 3, image 1 de 1
    • Remove the silver plate by gently pinching with your fingers.
  4. Sony NEX-5R Lens Mount Replacement: étape 4, image 1 de 1
    • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
  5. Sony NEX-5R Lens Mount Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Using the tweezers, grab the thin silver ring and lift up.
  6. Sony NEX-5R Lens Mount Replacement: étape 6, image 1 de 1
    • The camera mount should now be barren and look like this.
Emily Trujillo
Membre depuis le 04/08/14
1 114 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-9, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 2,666
