Aller au contenu principal
Sony NEX-5R Motherboard Replacement
Ce dont vous avez besoin
  1. Sony NEX-5R Motherboard Replacement, Front Case: étape 1, image 1 de 2 Sony NEX-5R Motherboard Replacement, Front Case: étape 1, image 2 de 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Motherboard Replacement: étape 2, image 1 de 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Motherboard Replacement: étape 3, image 1 de 2 Sony NEX-5R Motherboard Replacement: étape 3, image 2 de 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Motherboard Replacement, Rear Case: étape 4, image 1 de 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Motherboard Replacement: étape 5, image 1 de 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Motherboard Replacement: étape 6, image 1 de 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Motherboard Replacement: étape 7, image 1 de 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Motherboard Replacement: étape 8, image 1 de 2 Sony NEX-5R Motherboard Replacement: étape 8, image 2 de 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Motherboard Replacement: étape 9, image 1 de 1
    • The back case should now be removed and look like this.
  10. Sony NEX-5R Motherboard Replacement, Motherboard: étape 10, image 1 de 1
    • Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
  11. Sony NEX-5R Motherboard Replacement: étape 11, image 1 de 1
    • Remove the copper 2.25mm phillips head screw from the side of the camera.
  12. Sony NEX-5R Motherboard Replacement: étape 12, image 1 de 3 Sony NEX-5R Motherboard Replacement: étape 12, image 2 de 3 Sony NEX-5R Motherboard Replacement: étape 12, image 3 de 3
    • Use the spudger tool to unhook the neck strap anchor from the side of the camera with the navigation buttons.
  13. Sony NEX-5R Motherboard Replacement: étape 13, image 1 de 1
    • Remove the six copper 2.25mm phillips head screws from the top of the motherboard assembly on the camera
  14. Sony NEX-5R Motherboard Replacement: étape 14, image 1 de 1
    • Flip the main navigation button up behind the camera to further expose the frame
  15. Sony NEX-5R Motherboard Replacement: étape 15, image 1 de 1
    • Lift the LCD screen straight up and off of the camera. The motherboard frame is attached and the assembly will easily separate from the camera.
    • The lead connecting the LCD screen and the motherboard is fragile. Be careful not to damage the wiring or either end of the leads.
  16. Sony NEX-5R Motherboard Replacement: étape 16, image 1 de 2 Sony NEX-5R Motherboard Replacement: étape 16, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the lead connecting the LCD screen and frame assembly to the motherboard. Using tweezers, pull straight out from the lead to disconnect
    • Always work carefully when removing internal leads. These wires and ribbons are fragile.
    • The LCD screen and frame should now be separate from the main camera and appear as shown in the image
  17. Sony NEX-5R Motherboard Replacement: étape 17, image 1 de 1
    • Remove the small wire lead from the motherboard using the tweezers. Firmly grasp the lead wire near the connection and pull up from the motherboard at an angle. The lead will snap off of the mount.
  18. Sony NEX-5R Motherboard Replacement: étape 18, image 1 de 1
    • On the top left corner of the motherboard, unhook the black grommet from the housing by pinching the small tab with the tweezers and lifting up.
  19. Sony NEX-5R Motherboard Replacement: étape 19, image 1 de 3 Sony NEX-5R Motherboard Replacement: étape 19, image 2 de 3 Sony NEX-5R Motherboard Replacement: étape 19, image 3 de 3
    • On the top left side of the motherboard, remove the first lead from housing using the tweezers. Firmly grasp the lead with tweezers and pull straight out from the housing.
  20. Sony NEX-5R Motherboard Replacement: étape 20, image 1 de 1
    • Next, remove the first lead on the right side of the motherboard. Using tweezers, tightly grasp the lead and pull straight out from the housing.
  21. Sony NEX-5R Motherboard Replacement: étape 21, image 1 de 1
    • Remove the next lead on the side of the motherboard. For this lead, you may have to grasp it on either side with the tweezers as shown due to the lack of room beneath the lead. When securely grasped, pull straight out of the housing to remove the lead.
  22. Sony NEX-5R Motherboard Replacement: étape 22, image 1 de 1
    • Remove the final lead on the opposite side of the motherboard with tweezers. Tightly hold and the lead on either side and pull straight out of the housing to disconnect.
  23. Sony NEX-5R Motherboard Replacement: étape 23, image 1 de 1
    • On the lower side of the motherboard, you must remove the small metal frame that covers the socket-lead. Pinch the frame on each side with the tweezers and lift up to easily remove it.
  24. Sony NEX-5R Motherboard Replacement: étape 24, image 1 de 1
    • Pinch the cylindrical socket lead on each side with tweezers and lift out from its housing to remove the socket-lead.
  25. Sony NEX-5R Motherboard Replacement: étape 25, image 1 de 3 Sony NEX-5R Motherboard Replacement: étape 25, image 2 de 3 Sony NEX-5R Motherboard Replacement: étape 25, image 3 de 3
    • With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
    • The removed motherboard and camera body should now appear as shown.
6 autres ont terminé cette réparation.
Emily Trujillo
Membre depuis le 04/08/14
1 114 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-9, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 membres
14 tutoriels rédigés
3 commentaires
I have a Sony NEX-6 mirrorless...Is the process essentially the same?
Emily - Réponse
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
Norulhuda Azharruddin - Réponse
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
Harbert Wolfstein - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 49
Total : 7,822
